Urgent, or car will be towed!!
Old May 14, 2002 | 12:29 PM
85wilrocu's Avatar
Okay, can someone tell me if there is a fuse somewhere behind my dash? All the fuses in the fuse panel are good!
I got in my car turn the key and nothing, so i turn it back once more but i held it there and i heard a fuse pop!?
Please help stuck at work!!!!
Old May 14, 2002 | 12:34 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would check the ground to the battery.
Old May 14, 2002 | 03:36 PM
85wilrocu's Avatar
ttt
Old May 14, 2002 | 03:47 PM
Steve89GTA's Avatar
I don't think there's a fuse behind the dash. Do you have power otherwise (other than the starter?).
Check the power cable that goes from the batter to the starter motor (check connections at both ends). Your starter may be fried and you probably heard a fuseable link blow.
Old May 14, 2002 | 06:12 PM
gtabadboy's Avatar
Is the car turning but just wont start. If so check the fuel pump fuse. Should be in the front of the car drivers side next to the radiator. It's in a plug and needs to be popped out. If the car is not turning at all then I dont know sorry.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
