white smoke when starting
Old May 14, 2002 | 04:10 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
Hey guys, I need to know what's wrong with my car. When I first start my car in the morning it starts right up with no smoke, but after an hour or so , when I try to start the car it takes about 10seconds to start and a white cloud of smoke comes out of the exhaust. It smell like unburnt fuel. Do you guys have any idea how to fix this problem.
1988 Iroc=Z
350 TPI
700r-4 with B&M shift kit
2.77 posi
k&n with ram air induction
Old May 14, 2002 | 04:22 PM
RJR99SS's Avatar
heres the lowdown on smoke. a lot of people say WHITE smoke on this board at first, but then retract and say its actually blue or such.
White smoke: usually means water is getting into the cylinders. This can be a bad headgasket, or cars that have sat for a while sometimes will blow alot of white smoke for a few days. this is just due to water that has condensed in all of the systems due to unuse.
Blue smoke: this means oil is being burnt. The could be bad valve seals, or worst case the rings on the piston have gone bad; a compression test will confirm which one.
Black smoke: usually means excess fuel. What's called a "rich" condition in the engine, in carbs it means adjustment needs to be done. Its not too common in fuel injected engines however.
Old May 14, 2002 | 04:31 PM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
If it was a headgasket problem woulnd't it blow white smoke all the time when I start it. Because every morning I start my car and no white smoke comes out, but after a while when I try to start the car up, then a cloud white smoke comes out.If I was to wait 12hours after first starting my car, no white smoke would come out.
Old May 14, 2002 | 05:35 PM
RJR99SS's Avatar
well according to you, you have white smoke blowing all over the place. that would mean water is getting into the engine somehow.
are you sure its just purely white?
Old May 14, 2002 | 06:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
More than likely you have bad valve guide seals. The white smoke probably has a blue tinge to it. Stick you finger in the tail pipe and smell the residue. It's probably going to smell like burnet oil, if theres enough oil comming down it could cause firing problems after the car has sat for a few hours. If you were burning coolant, the tailpipes/smoke will smell sweet similar to sugar.
Old May 14, 2002 | 06:51 PM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Yes it smells like burnt oil. So if the valve guide seals bad, how do I go about fixing the problem.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
