got my new MAF on and still getting a code...
Old May 16, 2002 | 09:03 PM
tizzdizz's Avatar
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
I think this means its not detecting my MAF sensor?? I'm not sure. It was running really shiddy before i replaced the MAF; it would die at intersections, at idle...etc. now it seems to be running fine, but SES light is still on. I disconnected the battery for 10 minutes to make sure and reset the ECM. I don't know what else could be wrong.
I had to solder the connector onto the wires but I'm sure they're good connections. Any ideas?
P.S. off-topic Question, but my mechanic told me that I have POSI, cause all IROCs came with it, but I only ever leave one-leggers. I'm pretty sure its not. Is he right in saying that, and maybe my POSI is "burned out"? Can you "burn out" a POSI diff?
Thanks a lot guys.
Old May 16, 2002 | 09:10 PM
Bralgar's Avatar
Check your MAF wires mine did the same thing and I found they were chaffed near the alternater, and grounding aginst the block and brackets. Also, my IROC is NON posi, open diff, so I'd say your mechanic is missinformed.
Old May 16, 2002 | 09:17 PM
85transam1's Avatar
I am having the same thing.
I am having the same exact smae trouble so any help would be greatly appreciated.
Old May 19, 2002 | 02:07 PM
quiksilver1j's Avatar
I am havin a prob i have gotten codes 32, 34, and 36 at different times, but my car gets bogged down at first it will drive fine and then it will get just misfires but doesn't stall
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
