Check engine light for TPS or VSS sensor.
Old May 19, 2002 | 06:43 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Whey I really romp on it and drive the car in higher RPMs for about 5 to 30 minutes the check engine light will come on. I checked the book and it said something about adjusting the TPS (throttle position sensor). The other engine code Said something about the (VSS). Now one of these codes causes my computer to adjust something that causes my car to run slower. At this time If I hit the gas I can hear the engine working hard and I'll see the RPMs go up but the car has lost about 40% of its torque. Any Ideas?
>Oh yeah if I turn the engine off and clear the codes I get now problem at all.
Old May 19, 2002 | 02:46 PM
Guest
Guest
Posts: n/a
It would help if we knew what code you were getting and what induction and/or ecm you are using.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
