Hei?
Old May 16, 2002 | 10:05 PM
Fade07W's Avatar
Hei?
Okay I have just installed everything in my sig minus the ignition and distributor. Right now I have the OEM part number 30-1895 HEI distributor. With the ACCEL Super Coil. I know I still need to get a cap but first I have a couple of questions. As this is still my first motor swap I am a little confused about how to wire up the HEI. Do I need an external ignition box like the MSD 6AL or do I just need to run a power and tach lines? Basically what is needed from here to install the HEI? By the way I was an LG$ before this and as you can see have ditched all my computer stuff, AC, Smog, CC Carb, etc. So any help would be really appreciated!
Old May 16, 2002 | 10:19 PM
Fade07W's Avatar
Okay so I guess I might have given our the wrong part number but looking at the Distributor there is a green and white wire running into the module. Then there is are a tan and black and brown wire running out of the distributor in a plug. Is this a CC distributor? If it is what distributor should I ask for when I go to replace it?
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
