how to service an r4 compressor?
so my ac compressor locked up & fried the bearing in the clutch/pully assy. to save money i bought just the bearing so that i could get the pully to spin.
well. i couldnt get the bearing out. everywhere i take it from auto machinists to a/c shops tell me its either the wrong bearing or it cant b done at all. well i went to 3 different checkers & they all say the one i have is the right bearing. so why would they sell the bearing if it cant b replaced?
does n e one have experiance replacing this bearing & would b able to tell me how to do it?
thanx.
thanx.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
what exactly are you trying to replace? the clutch bearing (pulley/rim bearing)? if you are, i am going to do the exact same thing. i have ordered a # of tools for the job.
99-454 GM A6 and R4 Clutch Plate Remover
99-458 GM A6 and R4 Clutch Plate Installer
99-350 GM R4 Compressor Bearing Remover and Installer
22-1058 GM Staking Kit Bearing & Pulley Installer
these are the tools i ordered for the job. if you need any other A/C tools check these guys out....
MVPRO.COM
there toold are resaonably priced.
p.s. i'll let you know how it goes.......
MVPRO.COM
i think that is the same bearing.. im not too technical, but after u remove the clutch plate from the front of the pully assy it is the bearing that is in the middle of the pully assy.
well i got the plate puller from advanced auto & it started to break as i used it.. so my dad ground it down & straightened it & luckily it worked a second time. im not getting the installer because im just going to tap the plate back on.. my a/c wont work but the pully will spin & thats all i need.
thanx for the link im gonna c if 1 of those other tools is what i need though.
kymission
Jun 2, 2013 02:06 AM
lonsal
Southern California Area
Feb 19, 2003 03:40 PM
