Come on FUEL CELLS, anyone know anything??
Old May 17, 2002 | 06:24 PM
JucinGTA's Avatar
I did a search and saw that there wernt many replies to the topics
Has anyone conqured this Feat yet?
I found this pic and thats it.
Old May 17, 2002 | 06:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's mine. What do you want to know?
Old May 18, 2002 | 08:08 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
thats agood idea to comply with the rules. does the rubber seal to the hatch? how did you attach the wall to the sides of the car?what did the tech guys say?
Old May 18, 2002 | 08:52 AM
AlkyIROC's Avatar
Car: 87 IROC L98
I've redesigned the hatch seal since that pic was taken. That one sealed against the glass but I didn't like the lift shock area. I now have a sheet of aluminum attached to the hatch itself and it comes down and seals against that rubber seal.
It's attached to the side of the car with Manus body sealer.
It goes through the first tech inspection of the season this afternoon. I don't see having any problems.
Old May 18, 2002 | 09:38 AM
bob8748's Avatar
Man... that looks great: thumbsup:
Hope you dont mind if I copy your idea. Mine will be two boxes to clear the ladder bar frames. The plate on the hatch is a good idea also... glad I seen the pic.
Old May 18, 2002 | 11:57 AM
AlkyIROC's Avatar
Car: 87 IROC L98
There's another pic on my web site looking down from the other side. A Holley blue pump is down there also.
What you can't see is how I mounted the fuel cell. The threaded rod that holds the brackets goes through the firewall and then angled down into the floor. Every side of sheet metal has fender washers and nuts holding it all in place.
Old May 18, 2002 | 12:38 PM
bob8748's Avatar
Great pics
You have the same ladder set up that I have right down to the axle. Mine is cut to 41" with Strange 31 spline . And I am going with coilover shocks. Have no floor or rear framerails left. Wish I had pics.
:hail: One hell'va ride there... maybe someday we'll race!
Old May 18, 2002 | 03:57 PM
JucinGTA's Avatar
My ? is if I were to just put a cell in the trunk area, would that be NHRA Legal? It would also be mounted correctly too. Anyone every thought of putting it where the spare goes? You should be able to get a decent size in there.
Old May 18, 2002 | 09:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Mine past a tech inspection today. You just have to have it sealed from the drivers compartment. When my rear hatch closes, it seals against the rubber on the firewall.
Old May 19, 2002 | 03:57 PM
89ProchargedROC's Avatar
www.edquay.com for a complete kit but its pricey
Old May 19, 2002 | 04:44 PM
rhuarc30's Avatar
Forget the name of the company, but there is a company that makes fuel cells to fit in place of stock fuel tanks. I'll try to look it up for you.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
89fast5oh
Sep 27, 2015 09:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
