dont close mods
Old May 20, 2002 | 04:04 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
dont close mods
this doesnt pertain to third gens specifically but it is a tech question......when someone floors it in front of you on the highway and you smell that rotten egg smell.......i know this is caused by the catalytic converter but by what process is it attained and what is it you are actually smelling?
Old May 21, 2002 | 07:55 AM
wasp's Avatar
vader? anyone know?
Old May 21, 2002 | 08:24 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It's sulfur that you're smelling if I'm remembering correctly. And I hear that is signs of a clogging cat. Though I'm not sure, cause soon as I put a new one on I got that smell.
Old May 21, 2002 | 10:17 AM
BenDoe91z28's Avatar
alone the same lines.... i hit the speed govener in my car at 130 the other night... it was only there for a second and i started to smell something funny.... any ideas? it didn't really smell like clutch or oil....
Old May 21, 2002 | 10:23 AM
tpi_roc's Avatar
Probably your rings melting
Speed limiter means your fuel is cutt off, which means lean, which means dont hit your speed limiter.
Where in the northern oregon area did you find enough road to even hit your speed limiter
Old May 21, 2002 | 12:03 PM
Vader's Avatar
What you are smelling is sulfur dioxide gas, and is the result of a very HOT cat converter, not necessarily a clogged one. It is actually over-converting the exhaust gasses, since the optimal operating temperaure of a catalyst bed is somewhere between 500-1,600°F. Temperatures approaching or exceeding the 1,600° level can cause conversion to sulfur dioxide instead of CO², O², and water vapor, like a good cat should.
Old May 21, 2002 | 12:21 PM
I did it around 1:00 am on I5 near albany... gotta picture of it too, after i hit the govener though I guess i'll have to remove the govener next time i burn a chip... or maybe lower it to about 70 so i don't ever speed again??!
WARNING 443kb http://www.onid.orst.edu/~galvinb/whatthe.JPG
Thanks vader... I can see it all clearly now!
Old May 21, 2002 | 12:25 PM
tpi_roc's Avatar
If you listen closely..... you can hear your car say "Ouch ouch stop it"
Old May 21, 2002 | 12:29 PM
It felt solid as a rock at 120. No shakes or anything.. just the same as going 60..... I think the 1LE supspension probably has something to do with that.... once i got up to around 128 or so it started to hop a little bit, then i hit the govener and heard funny noises so i backed off.
Old May 21, 2002 | 12:31 PM
tpi_roc's Avatar
Mmmm 1LE
Come down here so I can touch your car
Old May 21, 2002 | 12:34 PM
you can see it! http://www.onid.orst.edu/~galvinb/myweb/veronica.htm
Old May 21, 2002 | 12:39 PM
tpi_roc's Avatar
Cool, decent car.
Next time I buzz through Ptown we oughta have a quick show down
Old May 21, 2002 | 01:02 PM
wasp's Avatar
i knew vader would answer it, thnx
Old May 21, 2002 | 10:14 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Pac J
May 17, 2020 10:44 AM
cheesehomer
Dec 31, 2015 08:48 AM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
