wont start
Old May 20, 2002 | 08:25 PM
blue dog's Avatar
wont start
'91 RS - I know real slow - 160k miles - stock and the paints falling off. But the real problem is she does not start - sometimes?
Lights work, radio plays, the battery seems good. I've jumpered around the trans lock out. The key switch seems ok. The starter is good and not temp. sensitive. Where do I look next?
Old May 20, 2002 | 08:31 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do you have VATS?
Old May 20, 2002 | 09:44 PM
Hulk0202's Avatar
Yeah, could be the ignition cylinder is going, or the chip on your key is not connecting, or is worn.
Old May 21, 2002 | 03:32 PM
irocz_ca's Avatar
what's the vats for?
Old May 21, 2002 | 04:16 PM
Vader's Avatar
Mark,
A '91 SHOULD have VATS. (Vehicle Anti-Theft System).
B-Dog,
I presume the engine won't even crank, correct? What does the "SECURITY" lamp do while you are trying to start?
Old May 22, 2002 | 06:57 PM
blue dog's Avatar
Reply - wont start
VATS - is the chip on the key part or all of it?
I don't know what the security lite is doing - but the next time it wont start I'll pay attention.
If it is the chip on the key - what's the solution?
Old May 22, 2002 | 07:04 PM
Hulk0202's Avatar
The chip on the key is only part of VATS. If the chip is bad, you have to either find the resistance value and add a resistor to the system,(search the archives you should find how to do it) or youll have to get a new ignition cylinder which will come with a new key. By the way VATS= vehicle anti-theft system.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
