Piston suggestions
Old May 21, 2002 | 10:15 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Piston suggestions
I just wanted some input from you guys on pistons for my rebuild. It will be a mild rebuild, nothing crazy. I was looking at either Federal Mogul hypereutectic or Speed pro hypereutectic, which is better? Is there another brand that is decent for my application? Both should retain near the stock compression also at 9.35 or so. Also, what is the difference between flattop pistons with 2 valve reliefs or 4? Is there advantages or disadvantages to either? Thanks for any input.
Old May 21, 2002 | 10:53 PM
32789RS's Avatar
You might want to take a look at KB hypertetic pistons, I have ran them in the past and was happy with them. not sure about the difference between the 2 or 4 valve relief, but i notice most pistons are 4 valve relief.
Old May 22, 2002 | 12:54 AM
Morley's Avatar
Aren't the valve reliefs for higher lift cams so the valves will clear?
With 2 valve reliefs you had to watch which way you had the piston facing in the cylinder, to make sure the valves actually went in them and not against the piston. With 4 valve reliefs you no longer have to worry about which way it faces, the valves will always be aimed at the reliefs.
At least thats how I believe it works, could be wrong.
~M~
Old May 22, 2002 | 04:07 AM
ede's Avatar
ede
reguardless of 2 or 4 valve reliefs there is still a " to front of engine" side of the piston usually marked with an arrow or notch
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
Dragonsys
Sep 25, 2015 03:51 PM
