Will an aftermarket oil pump driveshaft install from topside?
Old May 21, 2002 | 10:41 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Ok When I had my engine out of my car I replaced the oil pump, but When I got everything back together I realized I forgot the little plastic sleeve the couples the oil pump driveshaft to the oil pump. I would sleep alot better if IT had a sleeve on it, but I cant put the driveshaft dow nthe hole from the topside of the engine. The engine is already in the car and I do not want to pull it again and I really dont want to drop the oil pan while the engine is in the car. Does anyone know if an aftermarket oil pump driveshaft with a metal sleeve will fit dow nthe hole from the top of the engine?
Old May 21, 2002 | 11:17 PM
ronterry's Avatar
Car: '94 Corvette
If I remember right (been a while) yes it should.
Unlike the plastic sleeve setup, the metal one is pinned to the shaft, and dosen't require you to lock it in.
But I'm going on memory from a couple of years ago. Anyhow I'll post a pic I took of the pump w/shaft & metal sleeve.
Maybe someone else can confirm that the metal sleeve setup just slides on.
Ron
Attached Thumbnails Will an aftermarket oil pump driveshaft install from topside?-mvc-059x.jpg
Old May 22, 2002 | 04:14 AM
ede's Avatar
ede
you won't like this but no, at least the arp ones i use won't
Old May 23, 2002 | 03:30 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, I got the melling one from O'Reillys today and it doesnt fit in from the top. I guess for now I will have to run with no sleeve on the driveshaft.
Old May 23, 2002 | 05:21 AM
ronterry's Avatar
Car: '94 Corvette
Sorry 'Ward' but it's coming back to me now I remember having to remove the oil pump cause I left it out. I assumed it would fall threw if I installed it upside down. I remember catching the problem before I put the pan on while it was on the stand.
How close is it 'Ward' ?
Think you could grind the sleeve thin enough to fit ?
You might be all right with out it, but I can see how you would lose sleep over it, cause I would.
Ron
Old May 23, 2002 | 12:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You won't want to hear this, I can already tell....
It's no where near that close. The hole in the main cap where teh rod goes through has about 1/16" of clearance to the shaft. You can't really grind it that thin and expect it to work. Pull it now while your bearings are still good, or pull it later after your motor is trashed from oil pump failure. It's not worth the risk of breaking, which is near 100%.
Old May 23, 2002 | 03:05 PM
goneracin's Avatar
there is no way around it unfortunately, your going to have to pull the pan. I would not grind the sleeve, as its purpose is to hold the 2 pieces together, and if it fails, the pump WILL stop turning. You cant just put the stock shaft in the hole either, as it wont engage the pump correctly, or for long, and you will be into the engine again. Sorry to be the bearer of bad news.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
