Where is the relay for fan#2 ?
Old May 22, 2002 | 09:58 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
My second fan won't come on and I need
to check the relay.
Old May 22, 2002 | 10:28 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
This is on my particular car, yours could be different.
On the driver's side, against the firewall are three relays, all look exactly the same. The center relay is for fan #1, the relay closest to the driver's side fender is for fan #2. It's got four wires in it, but I can only remember 3 colors, orange, grey, and brown. (The last one might be black with a red stripe.)
HTH
By the way, my second fan is only set from the factory to come on when the pressure in the air conditioner lines is a certain pressure (meaning the A/C is on.) If you take that plug off the A/C line and short the two terminals in it (grey wire and black with white stripe wire) the fan should turn on when you turn the ignition on.
Old May 23, 2002 | 11:08 AM
Z03Z28's Avatar
Thanks.
I have let the a\c run for 45 min and it never came on.
Old May 23, 2002 | 03:08 PM
goneracin's Avatar
on my car, which is an 87 350 car, there is also a relay up near the fans. The prior owner had butchered a splice into the ground, and it would run all the time. I replaced the busted relay, and unhooked his splice, and it now works like it should.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
