o ringed
Old May 22, 2002 | 01:47 PM
fattie92's Avatar
o ringed
what does it mean exactly to "o ring" a engine? the guy that built my engine told me this was done, but didnt explain what it did. all he siad was that its a good idea to do that if your gonna run NO2.....?????anyone know?
Old May 22, 2002 | 01:49 PM
tpi_roc's Avatar
Good question
Old May 22, 2002 | 02:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Around the bore, you mill an o-ring indentation, do the same on the head (around the combustion chamber), and by putting a steel ring in that spot, you increase the sealing capability.
(If I'm way off base, someone correct me!)
Old May 22, 2002 | 05:08 PM
fattie92's Avatar
so the 2 rings expand from the heat creating a better seal? This is better for N02 becasue no2 makes your engine work harder creating more heat?
Old May 22, 2002 | 05:30 PM
ronterry's Avatar
Car: '94 Corvette
It's a prerequisite for copper head gaskets normaly used in super high compression engines.
Ron
Old May 22, 2002 | 05:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's only one ring per cylinder, but both the cylinder head and engine block have to be machined to accept the ring.
Old May 22, 2002 | 05:42 PM
fattie92's Avatar
ok, i think i get it...so im guessing the guy that had this block before me must of had a tight freakin engine!!
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
