car starts to hesitate badly...
Old May 22, 2002 | 02:57 AM
PPonU4Me's Avatar
When I am driving down the road and my car gets to about 4K rpm's, it will start sputtering and jerking and won't really gain anymore rpm. What would cause this? I need some ideas, the ignition parts come to mind, but I want other suggestions before I go out and replace all the accel parts on there, they ain' t cheap.
Old May 22, 2002 | 08:06 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Dirty fuel pump or clogged cat maybe.
Old May 22, 2002 | 10:04 AM
WaynesRS's Avatar
did you mean to say filter Mark ?
I think he meant to say dirty fuel filter .
Old May 22, 2002 | 01:34 PM
PPonU4Me's Avatar
hey guys, thanks for the replies. The fuel filter is a definite possibility, I will have to replace it. Anything else to check? The car doesn't have any cats so that isn't it. Any other suggestions as well would definitely be appreciated.
Old May 22, 2002 | 01:43 PM
WaynesRS's Avatar
maybe the fuelpump is not working properly , maybe when you get up to 4 k rpm its not pumping enough fuel .....First I would change the fuel filter ....Then if that doesn't do it , check your fuel pressure .
Man that paintjob is bitchen !!!
Old May 22, 2002 | 02:34 PM
Car: 99 Formula
Axle/Gears: 342
Yeah I meant filter. But like said the pump might be something to check too.
Old May 22, 2002 | 06:08 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Mine does this, I am getting a lot of knock retard on the scanner.
Something to look at.
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
L98GTA87
Aug 5, 2015 11:02 PM
