Roller cam's in 400's
Old May 22, 2002 | 02:26 PM
Torqomeo's Avatar
Just wandering what has to be done to a 400 to put a Hydraulic roller cam in it. Mainly a LT4 Hot cam? Im thinking i might start on the motor this summer with a simple rebuild with a Fel-Pro Max Torque rebuild kit. I got a buddy who works for NAPA and can get me the kit fro 500 cdn coin. here the Link http://www.sdpc2000.com/cart.asp?act...id=225&pid=560 However i don't like the cam. I would like the LT4 Hot cam instead. Slap on some World Sportsman IIs and go running with my TPI setup. I could only imagine the torque numbers a setup like that could make. Bye bye 9-bolt hello 12-bolt
Old May 22, 2002 | 02:45 PM
rhuarc30's Avatar
Nothing needs to be done to the block. You'll of course need retrofit roller rockers. The one thing that most people forget is to get a stronger timing cover, the roller cam will be held in place by a thrust bearing there, and most cheap ones will push out with the pressure, and screw up all kind's of expensive stuff.
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
masonta
Sep 1, 2015 06:40 PM
