Should a torque conveter wobble on the shaft of the tranny?
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I bought a rebuilt converter to go on a used tranny. I installed it to make sure it fit, the converter will move up and down and side to side if I push it with my hands. Is this normal? or should it be tight? There is no leakage around the seal from previous use. I can take a screw driver and place it inside the converter and move the second rear most spline thingy around. Could the converter be bad even though its a rebuild?
Ive swapped trannies before but never really took notice of how tight the converter was after it was on the shaft. I plan to install it this weekend but IM worried about the play in the converter. Any help would be greatly appreciated!
Thanks,
Mike
Thanks,
Mike
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
darwinprice
17
Oct 11, 2015 11:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
roysatikas
Sep 22, 2015 08:15 PM
