knocksensor wire ?
Old May 24, 2002 | 11:17 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
knocksensor wire ?
alright quick ? does the knock sensor wire, go directly from the knock sensor to the EST or does it branch off somewhere else? The reason I m asking is cause my wire is fried or broken somewhere in the middle. oh and cause the knocksensor wire on my 89 L98 is black where it connects, and white at the EST so I'm kinda lost right now.
Old May 24, 2002 | 11:24 PM
Jza's Avatar
Jza
The white knock sensor wire does go directly to the ESC module, no branches or side trips. White wires in the engine bay are often black near the connectors just from being exposed to the oily elements. If you clean off the knock sensor wire, I'm sure it'll be white at the ESC module as well.
Old May 24, 2002 | 11:33 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
well I thought that the knock sensor wire went only to the EST and then a wire from the EST went to the ESC, and I thought thought that the knocksensor didn't directly go to the ESC.
Old May 24, 2002 | 11:49 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Oh my bad Scratch the second post Im sorry I m tired, let me try it again.
well I thought that the knock sensor wire went only to the ESC and then a wire from the ESC went to the ECM, and I thought thought that the knocksensor didn't directly go to the ECM.
Well cause the reason I m asking is cause my buddy was tring to trace the wire and said it was black, now quick question what color is the fan switch wire? Cause I did a motor swap and was wondering if I had gotten these confused and switched, I really don't think so but I might of, but I dout it though cause my fans come on.
Old May 24, 2002 | 11:51 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
well I go out there tomorrow and wipe off the wire to see if it is white cause I think he traced it pretty far in the wire loom, but then again, it was night. I let you know.
Old May 25, 2002 | 12:17 AM
Jza's Avatar
Jza
Right. It's a white wire from the knock sensor to the ESC, then a black wire from the ESC to the ECM.
On speed density computers (90-92), the knock sensor feeds directly to the ECM via the white wire.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
