rear end troubles
Old May 25, 2002 | 12:02 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
rear end troubles
Do I need some kind of gear puller to pull the yoke for the driveshaft off the back of the differential housing? I got the nut off with an impact, but I cant get that part to budge.... any suggestions?
cheers
Old May 25, 2002 | 06:19 PM
dans82bird's Avatar
Engine: 302
anyone ???
Old May 25, 2002 | 09:20 PM
boogie's Avatar
Sometimes they are hard to break loose. A rubber mallet or a hammer and a block of wood should do the trick. Alternate sides when stricking.
Lonnie
Old May 26, 2002 | 07:50 AM
Vader's Avatar
A little penetrating oil on the spline can help. A puller on the flange with the screw on the input shaft shoudl get it moving.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
