Gas tank in position to replace fuel pump, now what?
Old May 25, 2002 | 09:49 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I spent a few hours getting my gas tank in position to replace the fuel pump (rusted bolts SUCK!). I decided to stop for the night. Now my question is, how do I get the pump out of the tank? There is a round thing with tabs on it. Do I do something with these tabs? Here is a pic (not my pic, I dropped the rearend instead of cutting a hole in my car):
This is what I am looking at with the tank dropped down out of the car. What do I do from here? The more details, the better. Thanks.
Old May 25, 2002 | 09:58 PM
86IROCZ's Avatar
You need to "unscrew" the center ring. The way that I did it was to tap the tab with a flat-head screwdriver and a hammer in the "lefty, loosey" direction untill the center ring popped out. If you look at real closely you'll see what I mean. Make sure you clean it first so that no dirt falls in to your tank when you get it open.
EDIT: Also make sure that you replace the strainer, fuel filter and the pulsator too or you'll probably have to do it all over again.
Old May 25, 2002 | 10:10 PM
BuckeyeROC's Avatar
Thanks, I have a new strainer, and a filter is no prob, but what is the pulsator?
Old May 25, 2002 | 10:23 PM
86IROCZ's Avatar
It's a little piece that goes between the fuel pump and the fuel line. When I did mine, the previous owner had just stuck a piece of hose there.
to me, it looks like a tiny little brake fluid resivoir (spell)
The new on slides into place and doesn't have any hose clamps.
EDIT: Oh yeah, I forgot. It's inside the tank. and it slides onto the fuel pump and the fuel line.
Old May 26, 2002 | 07:59 AM
Vader's Avatar
The pulsator is the short piece of hose between the pump and standpipe. The factory didn't always use clamps on these on TBI cars, but I'd install them for any type of fuel system.
Old May 27, 2002 | 03:49 AM
Jza's Avatar
Jza
Especially on a high-pressure system. The last thing you want to do after you have it all back together is take it all back out because it blew off without a clamp there.
Also, it's a good idea to use a brass punch instead of a screwdriver on that retainer ring. Brass won't cause sparks when it's smacked against steel, and sparks are bad around gas tanks.
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
