RPO codes??? (non thirdgen)
Old May 27, 2002 | 02:34 AM
JMBoriss's Avatar
I have a 1991 S10. I looked for the gear ratio RPO in the glove box and it says that it has both 3.42s and 3.73. The 2 codes are both in the RPO sticker? They both start with G. Why is that? Which ones do I have?
Jon
Old May 27, 2002 | 04:06 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
there is another code on the axle housing, I believe the passenger side front, Run the code here..http://www.hioutput.com/tech/ratio.html
oops forgot this is non 3rd gen....
Or you could take the inspection plate off and count the teeth on the ring gear and pinion....Ring gear divided by pinion =
hectre13
Dec 11, 2023 08:14 AM
lee01
Apr 9, 2016 01:56 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
