why do I have such bad wheel hop??
Old May 26, 2002 | 04:23 PM
TBI305Camaro's Avatar
ok my shocks and struts are shot to ****..i havent had time to do the struts but i did the shocks...KYB GR-2 shocks. now when I go around a hard turn that is even slightly uneven i get BAD wheelhop.. think its time for springs to?
Old May 26, 2002 | 05:46 PM
Joshua Leslie's Avatar
I had the same problem, but mine was more hard acceleration, it was so bad that the front speaker covers would come out of the dash.
I fixed it by putting on new struts/springs/shocks, and also a new set of tires.
Old May 26, 2002 | 06:48 PM
Hulk0202's Avatar
Do you get a bang when you launch? If so check your tranny mount. Hell check it anyway, it probably is part of the problem. Had the same problem after replacing clutch. New mount...problem solved.
Old May 27, 2002 | 12:02 AM
no no its not the tranny mount i know for sure. if i stomp it from a dead stop it spins then right as the spin was about to wear out WHAM WHAM WHAM its VERY bad. Im afraid im gonna break something i can get on it as hard as i want and it does fine but if i try to spin around a turn or from a stop it does it. Soon as i get the struts in ill see if it helps...if not i guess ill get springs to i plan on new tires anyways. my question is what would be causing the wheel hop?
Old May 27, 2002 | 01:24 AM
that is EXACTLY what mine did, I replace what I said, and it soved all problems(I even put in a 300hp motor from the 305tbi)
Old May 27, 2002 | 10:48 AM
i wonder what caused it? i dont see why installing new shocks would do that to a car i dont get it. maybe its not sitting right now since the struts are messed up?
Old May 27, 2002 | 10:54 AM
Steve89GTA's Avatar
LCA from STeve Spohn TOTALLY eliminated my wheel hop. Trust me!
Old Jun 15, 2002 | 03:38 AM
RBud350tpi's Avatar
hotchkis LCA and panhard squared me away
Old Jun 15, 2002 | 03:48 PM
iroc22's Avatar
Yeah its that damn stock suspension flexing that is causing the bad wheel hop. You gotta go for some aftermarket stuff.
Old Jun 16, 2002 | 01:52 AM
new tires got rid of mine mostly..you can feel it a tiny bit but not like it was. i will probably be ordering new sphon LCAs soon tho.
Old Jun 16, 2002 | 06:13 AM
ZZsmpch's Avatar
Get some poly bushings and put them in there. While you have the lowers out, get some steel from the hardware store and box them. It's a hell of a lot cheaper than buying aftermarket stuff and works great. The relocation brackets are a great idea too.
Scamo-2.8
May 20, 2016 07:01 PM
IroczFan
Oct 6, 2015 10:13 AM
dyeager535
Aug 28, 2015 08:10 AM
B_Dubya
Aug 26, 2015 05:09 PM
