Clicking Lifter??
Old May 26, 2002 | 06:51 PM
Buck268's Avatar
Clicking Lifter??
What would a "clicking lifter" sounds like? I have some noise - sounds kinda like ping, but A LOT quieter - between 1000-1500 rpms, it almost always does - but I think it might have stopped for a little while after I changed my oil. it sounds kinda like a tapping, or knocking - metal on metal - but pretty quiet IMO. Anyone got any ideas. Been trying to figure this out since maybe Januaary, but I havent gotten anywhere....
Oh, it gets louder/intenser if I do a brake stand (like when you go 2 launch at the strip)...
Old May 26, 2002 | 07:17 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i guess you want to kill your tranny and pay for more tires
Old May 26, 2002 | 07:27 PM
iroc22's Avatar
You should check for some exhaust leaks. Even the gasket-less manifolds can leak (ie broken bolt). Does the sound intensify under load? A bad lifter will also make a similar tapping sound however.
Old May 26, 2002 | 07:41 PM
Buck268's Avatar
yes - the sounds most certainly does intensify under load. So that would lend itself to an exhaust leak??? Also, is there anyway to tell if its a lifter w/o tearing the engine down? And when I said 1000-1500 rpm's I meant when i am driving - at the track, i only brake to about 1000 rpm's...
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
Linson
Oct 1, 2015 09:50 PM
sahlomonic
Sep 20, 2015 07:15 PM
