Help!!! What should my timing be??
Old May 27, 2002 | 08:29 AM
Tranny Man's Avatar
I was trying to do a full tune up on my stock L03 (88) auto. I cant find the VECI label. I have an emission test coming up and need to pass!! What is the stock timing with the EST disconnected? Keith
Old May 27, 2002 | 07:38 PM
ede's Avatar
ede
you ought to own a manual to look it up for sure but a WAG is 6 or 8 BTDC
Old May 27, 2002 | 08:24 PM
Jza's Avatar
Jza
L03 autos run at 0° BTDC. Just set it straight up.
Old May 27, 2002 | 08:35 PM
TBI305Camaro's Avatar
i found by setting the timing at 0 degrees with the EST the computer retards the timing even more. I even have only 93 octane in there...I keep it set at around 10 degrees without the EST hooked up then when i hook it up it takes it to about 20...seems alittle high to me but i guess the computer knows whats up
Old May 27, 2002 | 08:47 PM
Tranny Man's Avatar
I have the Haynes manual they just tell me to disconnect the EST and set it to the VECI label. Lots of help that book is thats is why I posted the Q here! Jza is 0deg with it disconnected? if that is the case then I'm 4deg to far advanced Keith
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
