Changing the Fan from Comp. to Thermal Switch
Old May 27, 2002 | 09:27 PM
85TPITransAM's Avatar
Is it possible for a single fan to be run off of the sensor in the cylinder head instead of the computer? I have a single Fan motor and do not have the money to convert to dual fans at the moment. Thanks.
Old May 27, 2002 | 11:07 PM
bumpity bump
Old May 27, 2002 | 11:19 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes, but the unit your looking for is rather expensive, as in almost costs as much as another electric fan. Azone and other parts store carry a little fan relay where you can adjust activation temp and it only runs $18. the only problem with this one is, it uses and externaly mounted sensor that attaches the the radiator, IMO not very reliable for a long period of time. I use this one and havent had any real problems.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
TA8487
Aug 16, 2015 12:21 PM
92camaroJoe
Aug 13, 2015 06:07 AM
