Pro's and Cons of Fan usage
Old May 28, 2002 | 09:04 PM
85TPITransAM's Avatar
I am currently wiring my fan to run constantly while the car is cranked. I want your opinions. I am only doing this until I get my dual system in about 2 months. Thanks.
Old May 28, 2002 | 09:09 PM
Jester's Avatar
no cons really. I keep mine like that permenantly,.
Old May 29, 2002 | 09:04 AM
Vader's Avatar
85,
Your fans will wear out sooner, but if you're getting a replacement soon, that probably isn't an issue. The only other possible problems are that the alternator always has to work harder to generate the 12-15A to run the fan, and if you're using an auto with a trans cooler, the trans oil will take a little longer to warm up and thin out (high line pressure).
And Jester, I'm thinking you're probably making just a little more heat than '85 might be. How's the inverted radiator working out?
Old May 29, 2002 | 10:33 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i have my fan wired like that. and i just picked up my new one today because the other one burned out on me. im on my 3rd fan in 3 years. so they do go faster when on all the time.
Old May 29, 2002 | 01:34 PM
Jester's Avatar
It fit and worked fairly well..but it turned out to just not be enough to keep it cool. I managed to pick up 6 core thick radiator. Used Nascar throwaway I found for cheap. works much better
I put up pics of the radiator and install if you wanna see.
http://jester.iroczone.com/Radiator.html
Old May 29, 2002 | 02:12 PM
Yeah.....I'm gonna get a replacement in a few months. I am running an Auto but I only need this as an alternative for the moment.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
djmarch
Oct 2, 2015 10:41 PM
Fanatic1074
Oct 2, 2015 03:47 PM
