Whats an auxillary valvebody
Riley,
In the middle of the 1986 production year, the TH700-R4 was fitted with a modified valve body with a provision for mounting an additional auxilliary valve body. The additional valve body is mostly an accumulator of sorts for forward clutch engagement. This smoothes the "apply feel" for DRIVE, but there can still be a noticable "jerk" into DRIVE. There is also a check ball in the case to slow and smooth the reverse clutch engagement.
A few other changes were made by Hydramatic at the same time, including a new transmission oil pump with more vanes (ten versus seven) for less pulsation and noise, a change in the mounting of the pump input shaft bushing, the change from a single slider spring to two on the pump, and a few other minor refinements like increased oil passage sizes for the oil pump discharge, lockup valve, etc.
My late '86 (July '86) has the newer style trans. Anything after that should also have the changes. There is supposedly a subtle difference in the trans oil pan on cars with the auxilliary valve body. Those with the auxilliary body supposedly have a slightly deeper pan that is completely flat on the bottom,but I haven't been able to verify that. Anyone want to clarify this?
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Thanks Vader mine is an 83 so I dont have it....I just took the valve body apart I only came up with 6 checkballs instead of 7. I had the tranny on its back...i hope to CHrist the #7 isnt in the case ...
I only need 6 put back in so I guess I'll keep going and hope for the best...I'm for sure not going any deeper...
Engine: 406
Well the kit is in....And yes I did need 7 *****...4 inthe case 3 in the VB...Now I have 8, 7 where they belong..., and 1, the good lord only knows....as for installing these transgo kits while in the car....anybody that has done it...:hail:
I couldnt imagine doing it that way...Now all I need is 2 able bodies to put this thing in for me, I just had neck surgery 3wks ago, I'm not quite ready for the weight...guess Ill have to cash in some markers..
Cant wait to try it out...Now the shifter
fast89
Apr 15, 2001 09:32 AM
