how much difference will i see from msd 6a and blaster 2 coil?
Old May 29, 2002 | 06:08 PM
Marshall89ws6's Avatar
yea i just ordered the msd super hei kit which includes the msd 6a box( i got the 6a instead of 6al cuz i have auto and dont really need the rev limiter) and the blaster 2 coil..... i already have msd 8.5 mm wires...... how much difference should i see?
Old May 29, 2002 | 06:19 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Exactly nothing. The stock ignition has no problem keeping the fire lit on anything but the hottest combinations.
Old May 29, 2002 | 06:29 PM
thats funny how everyone knows everything..... well seeing as i already installed it and dynoed it and filled up since i have it....... i got about an 8 hp increase over the last dyno....... and 20 more miles to a full tank...... plus more top end power....... just wanted to hear some storys from ppl that actually have them also.... thanks
Old May 29, 2002 | 06:33 PM
poncho9789's Avatar
Ed is right a msd 6 wont' give you any more power. All it does is give you a more complete fuel burn which the stock unit you have on your 89 should be more then up to the task. If you have a 87 earlyer distributor then the msd will give you more spark above arround 5k. I have one so I can use it for the soft touch rev limiter and for an ignition retard for my nitrous system.
Old May 29, 2002 | 06:41 PM
well according to the dynos i gained a little power from it....:lala:
Old May 29, 2002 | 06:43 PM
ZBRA's Avatar
Car: 1972 Corvette
Re: how much difference will i see from msd 6a and blaster 2 coil?
Depends. Did you also install the enclosed "MSD Ignition" sticker?
Old May 29, 2002 | 06:46 PM
Boxeat2469's Avatar
You also need to consider whether or not your old stock ignition was operating at 100% capacity. You probably could have installed a brand new OEM ignition and gained the exact same 8 hp and 20 miles per tank. Your really comparing apples and oranges when you replace a used part with a new part from a different manufacturer.
Old May 29, 2002 | 06:49 PM
Ed Maher's Avatar
Car: 04 GTO
If an MSD box was worth power on a stock motor, don't you think i'd be running one? Notice my car is basically stock, and also one of the heaviest thirdgens off the line yet it runs pretty well. If an MSD was such cheap easy HP why wouldn't i use one, just so i can make smart *** comments on a message board.
I've never heard a single real gain from anybody that is respectable except for on cars that 'need it'. And that includes being at the track and doing back to back runs and seeing the same timeslips on a couple of cars.
The stock ignition has no problem making a spark in the kind of RPM range and cylinder pressure that naturally aspirated street engines make (well most anyway) . It's not like it makes a spark but it doesn't completely light the mixture. Thats called a miss. And it's indicative of poor tuning or a malfunction. The fact that so many cars have made solid power on stock ignitions is proof of that.
Old May 29, 2002 | 06:51 PM
Ed Maher's Avatar
Car: 04 GTO
First you just ordered it. Now you have dyno results. Isn't it past your bed time?
Old May 29, 2002 | 07:08 PM
Biochem's Avatar
Car: 2002 SOM z28
Probably because your stock ignition system was so used that any new wires/coil/etc. would have given you a bit more power on a dyno than your 13 yr old stock wires and HEI
Old May 29, 2002 | 07:37 PM
novadude's Avatar
Ed is right.
Hell, I installed one to replace my 40 yr old POINTS distributor, and it did not do anything!!!! 14.2@ 98 before, 14.2@98 after.
Point is, even a 1930's technology breaker point distributor works fine for most mild n/a applications. YOU WILL SEE NO GAINS FROM UPGRADING!
You should have ditched the TBI and bought a carb with the money you spend on the MSD!
Old May 29, 2002 | 07:44 PM
wataru's Avatar
I've had the box, coil, and wires on my car for about a year now. No diff. except I picked up a few more mpg and thats probably from replacing the old stuff.
Later Barrett
Old May 29, 2002 | 08:04 PM
poncho9789's Avatar
I have noticed a mpg diff from installing a ignition box but not a power gain.
Old May 29, 2002 | 08:23 PM
nah i just said that so somebody would walk right into something cuz a lot of info i get here isnt very true..... although a lot of it is, some is utter bull****..... just wanted to prove a point..... and you guys are probably right.... my stock ignition was probably ****ty but my wires and plugs were new.
Old May 29, 2002 | 08:24 PM
Bort62's Avatar
LOL I love how the Guy Manged to Receive his order, get it installed, AND Dyno it between 3:08 and 3:29 IN the same evening.
Damn, Thats what I call Efficent!
Old May 29, 2002 | 09:46 PM
actually the point of my last post is that i have had it installed and simply said i just got it to see what kind of bull**** would pop-up from some ppl.
Old May 29, 2002 | 09:51 PM
someone in the exhaust section tried to tell me that mustangs had 4 cats...... i was curious as to see what ppl would say
Old May 29, 2002 | 09:56 PM
Brad's Avatar
And my point is that if you're just here to stir up bull****, you're going to find yourself banned pretty fast. Consider this a warning.
junior419
Apr 7, 2025 11:35 AM
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
