foamy coolant
Old May 29, 2002 | 12:40 PM
LeftTurn1LE's Avatar
foamy coolant
Hey guys, summer is finally here, and I see its taking its toll on a lot of engines this week. There's quite a few cooling problem threads on the board today, and alot of cars in parking lots with the hood open.
I replaced my thermostat yesterday, and when I was filling my radiator I noticed the coolant was starting to foam. I had the engine running and the heat on. What causes this? My other camaro used to do the same thing. Is it normal?
Old May 29, 2002 | 09:11 PM
TTT
-new heater core
-new thermostat
-all hoses are in good shape
-no leaks anywhere
Old May 29, 2002 | 11:27 PM
ronterry's Avatar
Car: '94 Corvette
I've seen foam from 40 below, detergents, and other additives.
You might have some residuals additives still in the system.
You can try flushing the system till the water is cyrstal clear, and then adding coolant/anti-freeze.
Ron
Old May 29, 2002 | 11:37 PM
SlowStangEater's Avatar
Foam can be caused by residue.......but if its bubbly foam it could be a cracked block or head.
Old May 30, 2002 | 12:13 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would add a 30/ 70 percent coolant to water ratio. More water than coolant should run a lot cooler.!
Old May 30, 2002 | 12:15 AM
I dont think hes overheating? Just has foam......If there is any cracks in the block it could allow just enough air in to cause foam........Probably nothing to worry about.
Old May 30, 2002 | 03:14 PM
Yes, the foam is bubbly like soap suds. I guess I'll flush the system and see if it still foams. I hope its not a cracked block or heads.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
