Alternator Wiring ?
Old May 29, 2002 | 10:45 PM
ronterry's Avatar
Car: '94 Corvette
Alternator Wiring ?
Ok.... There's a total of (3) wires, (2) Red, & (1) Black.
A connector that has a red & black, and one red wire that goes on a post on the rear of the Alternator.
Pop Quiz, where does each wire run? Extra credit if your specific!
Thank's , I need to wiring in a Kill Switch. I'm also considering a (1) wire conversion? any pros - cons ???
Ron
Old May 30, 2002 | 05:08 PM
ronterry's Avatar
Car: '94 Corvette
OK the Black wire goes to a dummy light, the red wire(s) are connected in the loom, and run to the bat terminal on the starter solenoid & driver side junction.
hmm I'll have to figure out what's the purpose of it running to the junction?
Now the fuse box also gets a separate fusible link wire from the solenoid. So it’s purpose is odd, unless it’s there to provide relief for the other main fuse box wire.
I've heard that 10S's needs to have the energizer wire switched but obviously that's not the case since there connected at the factory. However the wire going into the junction is ran threw a fusible link, just like at the solenoid.
Ron
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
