Engine gasket set question, what to get?
Old May 30, 2002 | 07:56 AM
mefreema's Avatar
I am going to rebuild the top end of my motor and had a question about the gaskets. I would like to do a little porting on my intake and exhaust ports on my heads as well as the intake manifold. I belive the term is "gasket matching". I dont want to hog it out very much but just clean things up a little and do some polishing on the exhaust ports. The heads are Dart Iron Eagle 200cc (if that makes a difference). Do I just buy a standard set of gaskets and port it out to that size or should I be buying a custom size gasket (for intake to heads)? What brand would you reccomend too? I will have 9.5:1 compression and be running a 50-75-100 shot of N20 as well. In case I need a special head gasket to help hold the seal. Thanks! :lala:
Old May 30, 2002 | 10:31 AM
Vader's Avatar
Re: Engine gasket set question, what to get?
Originally posted by mefreema
...What brand would you reccomend too?...
The factory GM gasket sets are hard to beat for quality and price. The dealers can get tham if they're not in stock (that would be a surprise) and they are often half the price of the Fel-Pro sets. They worked for the first 10 years, so you can expect the same quality or better for the next ten at least.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
