Overdrive Problem
Old May 31, 2002 | 07:03 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
Overdrive Problem
I have an automatic V6 1988 Camaro and I’m having a little problem. I just had a tune up and an entire lube job and my car is still acting up. When I accelerate I can fell the car going through the gears up until I reach about sixty. When I reach sixty the RPM's drop down to 1500 even with my foot to the floor. I try taking my foot of the gas and stomping on it with no luck. I tried pumping the gas with no luck. I find myself having to put a pint of trans fluid in every week. I can't find a leak, so i don't know where the trans fluid is going. Even when the tran is full of fluid it still doesn't work. I was told it might be a cracked flexplate, and someone told me to adjust my TV cable. Does anyone have any idea how to correct this problem.
Old May 31, 2002 | 07:40 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Try posting on the transmission board. You would get a better response there. Try putting a piece of cardboard under the tranny, my bet is it is leaking from the speedometer cable.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
84 TA NV
Sep 6, 2015 08:02 PM
andy74
Sep 3, 2015 08:41 AM
