ECM install
Old Jun 3, 2002 | 10:22 PM
5.7GTA's Avatar
ECM install
Hi,
I bought a fastchip from ed wright and also got a 160 degree thermostat. I put the thermostat in....what a pain in the rump that was. Anyways I finally pulled my ECM out and put the new chip in. Now the problem is that I can't get the ECM back in the dash. Any tips would be very helpful. Do I need to take the dash piece out that is directly behind the map sleeve or do I have to bend myself into a pretzel and finesse in up in there.
Thanks, Derek
Old Jun 3, 2002 | 10:44 PM
1986redbird's Avatar
there is plastic pin on the ecm carrier that must slip into a hole at the top of the dash before the bolts at the bottom will line up right.
YES you may need to bend yourself into a pretzel to get it in.
Jae992
Aug 27, 2015 09:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 19, 2015 12:07 PM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
