head specs, please?
Old Jun 4, 2002 | 08:14 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
head specs, please?
hi guys.
i have a camaro with a 350 (5.7) engine on, (just bought) and the casting numbers on my heads are 14102193, on the car said, cross fire inyection. that's ruined so i'm going good old carb, but i believe those heads require a special manifols 'cause of the center bolts positioning, is that true? anyway it will be nice to me to know about the specs on the heads, things as...how many cc's on the combustion chambers and valve sizes?
the block is 100054727, and as per mortec is a 86 and up 350, so i believe it is the 1pc main seal?
thanks to all.
Fernando.
Old Jun 4, 2002 | 12:44 PM
iroc22's Avatar
All cross fires were the old pattern.
If they are 350 heads, they're 64cc and probably 165cc runners or so. Valves will be 1.94/1.5
Old Jun 4, 2002 | 02:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Somebody's done some mixing there. The heads are '87-up 350, so, the cross-fire had to be modified in order to make it fit.
The block is '86-up 350 (I think you have one too many zeros in that casting number), therefore, as it says, one-piece rear main seal.
You need an '87-up intake to use those heads, or modify the center-two bolt holes on each side of an '86-earlier intake manifold.
Old Jun 4, 2002 | 02:56 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
yep.
nothing is original on that babe.
anyway i just wanted to know the size of the valves and the chamber.
and sure i'm scrapping that injection crap and go ol'school (carb)
Fernando.
Old Jun 5, 2002 | 01:46 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
i have an answer from our friends at MORTEC. they are :
valves 1.94 I
1.50 E
76cc on the combustion chambers.
for those who have the same heads. (14102193)
Fernando.
deracer
Apr 11, 2016 12:04 AM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
