Stalls at cold start
Old Jun 4, 2002 | 09:06 PM
cllimp101's Avatar
I have a 85 z that when u first start the car, after it has been sitting all night it will start then if u dont hit the gas will stall right out.?? any ideas what might be wrong? Has been happeingin for a while now. After the car runs about for 5-10 min it runs and ideals normally again. I am lost, i have cleaned the intake and replaced the sparkplugs and such. still same thing happens whenver i go to start it no matter how hot or cold or what time it is? Well any idea's thnx
Old Jun 4, 2002 | 11:42 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
im not too good with carbs but it sounds like a choke problem
Old Jun 5, 2002 | 01:24 AM
blk91z28's Avatar
It might be a sticking injector leaking fuel into the motor and flooding it out.And when you first start the car up you have to burn the extra fuel off.
Old Jun 5, 2002 | 06:54 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
What kind of fuel system DO you have. We need to know.
Old Jun 5, 2002 | 08:05 AM
cllimp101's Avatar
O sry about that i am a moron. I have a 350 TPI. Thnx for the replys.
Old Jun 5, 2002 | 01:53 PM
FstBrd6point3's Avatar
my 383 TPI does the same thing, starts, runs for bout 2 seconds and then stalls, and then U start it back up and it bogs for a quick second but then runs "normaly"... I will s ee if it still does it once I get the new injectors and everyhting in with the new LT1 intake.
Old Jun 6, 2002 | 10:32 AM
Vader's Avatar
101,
Possibly the cold start control or cold start injector. It would also be a good idea to check/clean the TB and IAC, and check/set the TPS voltage.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
