car wont start...
Old Jun 5, 2002 | 01:54 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
car wont start...
thats about it, my car wont start. i turn the key to start and nothing happens. thr battery is good, alternator is good. a couple of days ago i wopuld turn the key ro start and the car wouldnt, bvut after a couiple of tries it turned over. now, nothing happens. help....
Old Jun 5, 2002 | 06:44 PM
curt86iroc's Avatar
Car: 1990 IROC
anyone? i need help fast....
Old Jun 5, 2002 | 07:24 PM
383 rocket bird's Avatar
When you try to start the car do you hear a click or nothing at all? When you were trying to start the car before when you first tried was it starting right up after a few tries or was it cranking slowly?
Old Jun 5, 2002 | 08:59 PM
84TransAm's Avatar
you could check your the bolts for your clamps on the battery
Old Jun 5, 2002 | 09:58 PM
curt86iroc's Avatar
Car: 1990 IROC
i hear a very quiet clicking which makes me think starter.....just replaced it about 6 months ago. ah well, guess ill pull it and get a replacement....
Old Jun 5, 2002 | 10:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
not so fast! make sure you check ALL the connections. If they look the slightest bit corroded, clean them. Trust me on this, if the starter and solenoid are still good, your problem is probably here. I cant tell you how much trouble me and my brother have had with this, especialy the ground strap on the front pass. side cyl. head. He even ran a ground strap to the starter itself.
P.S. A good way to check is, if the positive cable to the starter is clean and good to go, hook a jumper cable up to the starter body (bell housing is good) and run it to the negitive term. ont he battery. see if that helps.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
