LG4 Timing : 0° or 6° ???
Old Jun 5, 2002 | 04:12 PM
Tom H.'s Avatar
Hi,
a friend own a 85 Camaro with LG4 engine. He can't find the "emission sticker" and he wants to adjuste the timing.
So I searched for the stock value on this board : some read 0° BTDC on their stickers and others have 6° BTDC !?!
How can you explain ? Year ? Califonia ?
Thanks !
Old Jun 5, 2002 | 04:53 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
On my 86 IROC the sticker reads 0 deg. I think the 6 deg is eithert for the 305 H.O. or peoples preference. I do believe though that all computer controlled LG4's are set at 0 deg (somebody may correct me though). Don't forget to disconnect the 4 prong connector at the distributor before setting it!
Mark
Old Jun 5, 2002 | 05:00 PM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
My lg4 is recomended for 0* BTDC, but i'm running somewhere around 6-8* BTDC... runs better.
Old Jun 5, 2002 | 08:23 PM
Tom H.'s Avatar
Tanks a lot !
Well, there's one topic where someone says he reads 6° on his sticker :
https://www.thirdgen.org/techbb2/sho...threadid=26112
The sticker on my '84 LG4 with a Q-jet says it's 6*btdc
Old Jun 6, 2002 | 09:13 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I just bought a new sticker for mine and it says 6*. How odd.
Old Jun 6, 2002 | 11:41 AM
Tom H.'s Avatar
So ??? Any idea ?
Old Jun 6, 2002 | 12:14 PM
TransAm's Avatar
my sticker says 6* btdc aswell... that's for 85 w/the q-jet.... perhaps it's the difference in carb / tbi / tpi / crossfire that accounts for the different settings
Old Jun 6, 2002 | 01:16 PM
Car: 1986 IROC
Originally posted by TransAm
my sticker says 6* btdc as well... that's for 85 w/the q-jet.... perhaps it's the difference in carb / tbi / tpi / crossfire that accounts for the different settings
My 86 IROC LG4 w/Qjet says 0 deg, just double checked. I think it is really weird that LG4's would have different settings between years. For some reason, the 86LG4 hd like 5 more HP and TQ than the 85, but the compression is the same. I would just set it at 3 deg BTDC and leave it at that. It shouldn't knock or anything, I have mine set at 6 deg.
Mark
Old Jun 6, 2002 | 01:59 PM
99Hawk120's Avatar
Forgot to mention, mine's for an 84 (with no knock sensor). Why would they DROP the base timing when adding a knock sensor (in 85)? That don't make no sense.
Old Jun 6, 2002 | 02:04 PM
Tom H.'s Avatar
But a LG4 is a carb engine... If it's a TBI or a TPI, it's not a LG4, but a LO3 or LB9
Well, does the transmission (auto or man) can changes the prefered timing setting ? I guess the answer is "no"...
Old Jun 6, 2002 | 04:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Best info I've amassed says LG4, 0 degrees; L69, 6 degrees. Type of tranny didn't change anything. If you got a "new" sticker that says 6 degrees, it's probably an L69 sticker.
Most LG4's run fine with 6 degrees. Although I'm running 10 degrees right now and still using bottom grade unleaded with absolutely no pinging problems. Run the most that you can get away with, without having to use higher octane.
Power rating is more than just compression. Exhaust will affect what number they give it.
Old Jun 7, 2002 | 10:49 AM
99Hawk120's Avatar
That could be. The three letter code on mine is XJW, if that helps anyone figure it out...
Old Jun 8, 2002 | 09:06 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
my orignal sticker said 6* and it was a LG4 (right now it's computer controled and it runs it all the way to 50* total during certin points, and it hasen't pinged once yet )
Old Jun 9, 2002 | 03:30 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
The original sticker on my 83 Trans Am with the LG4 says 6* for both stick and automatic. Im running about 12* right now with no problems and its already 110 degrees out here in PHX adn im running 87 octane.
Old Jun 10, 2002 | 03:38 PM
99Hawk120's Avatar
To add another point, I found an almost completely bone stock 83 Z28 in the junkyard on Saturday that was an LG4 right down to the single snorkel and the label also said 6*, and it was a completely different three letter code than mine.
I'm beginning to wonder if the difference isn't the California emissions. Classic industries only lists two labels for 84 Camaro 305--one with Cali emissions and one without.
RazorN8
Jan 7, 2022 11:44 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
