Whats the cam specs of a l98??
Old Jun 6, 2002 | 11:29 AM
TBI305Camaro's Avatar
Im probably gonna buy a l98 shortblock soon (1100$) and i was wondering how the cam was...is it worth keeping? Basically it is just the block, crank, rods, pistons and thats about it. so i will have to put some money into it but i figured its better to go that way than buying a lo5 for 1500 that comes with crappy heads...i dont know anyways hows the cam in the l98?
:edit: actually I got to looking and the lo5 would probably be cheaper even if i did away with the heads since it does come with oil pan, pump, harmonic balancer, timning chain and all that good stuff...what kind of power do you think I could get from a lo5 with the stock heads?
Old Jun 6, 2002 | 11:35 AM
Jester's Avatar
It depends on the year..they changed. Either way none of them were very good..you should replace it while you have the motor out anyway.
Old Jun 6, 2002 | 08:04 PM
thats what ill do then. i know ill definetly have to change the lo5 cam if thats what i get i hear its worse than the lo3 cam. im leaning towards the lo5 crate now because it will have lifters and everything.
lt500r55
Sep 1, 2021 01:30 PM
masonta
Sep 1, 2015 06:40 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
italiano67
Aug 31, 2015 06:04 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
