HELP!! A/C Compressor seized...need to re-route belt!
Old Jun 6, 2002 | 09:41 PM
gonzo350's Avatar
OK 1990 iroc serpentine. A/c compressor just seized...not enough time to replace it......I need to know if I can by-pass it by running off the smog pump, under the tensioner pulley and continue it's normal route. Anyone know if this will work and if so how long a belt? No time to do the delete thing...have to get to work and mother to the airport! Thanks!
Old Jun 6, 2002 | 10:29 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
does teh pulley ( the inner grooved thing) still rotate freely when the a/c system is off? if so you can just put a new belt on and replace later. Other thatn that, you'll hafta get creative. I thought of doing the same thing but i dont think its possible to route it correctly. Anyone else know?
Old Jun 6, 2002 | 10:34 PM
Jester's Avatar
Try super shuttle, they're pretty reasonable for airport runs.
I think you're stuck. I don't think there is a way to just run a belt over the smog pump and still have it reach the tentioner.
Old Jun 6, 2002 | 10:44 PM
gonzo350's Avatar
the compressor pulley is the problem...that is what has failed (gawd auwfull noises from under the hood let me tell you!) I took a piece of string and routed it from over the alternator, around the P/S pump. under the crank pulley, around the water pump, under the smog pump and back to the alternator....took all the tension off the tensioner pulley and measured 84" I THINK I might just get enough tension on the belt to hold me for a little while till I can fix things correctly......any opinions?
Old Jun 6, 2002 | 11:17 PM
Car: 88 Camaro SC
Engine: SFI'd 350
make sure all the accessories are driven in the same direction as they where before you route it around.
Old Jun 6, 2002 | 11:45 PM
slowV8berlinetta's Avatar
you need a special pulley either from the dealer or from a junkyard for a car that didn't have AC. I removed the AC from a friends TPI, and used to be a dealer tech, so i got a deal on the pulley and bracket that goes in place. It was like $40 wit my discount, don't remeber what it would've been without, but prolly at least $60. I think that we still used the same belt, and the routing was still the same. Not sure though, abd don't know the part number.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
