coolant question (thermostat)
Old Jun 12, 2002 | 01:48 PM
86-red_dawg's Avatar
i've been running very hot lately, and decided to see if maybe the thermostat was at fault - i didn't have another one handy, and i'd heard alot of people talk about not using one at all in the summer time, so i removed mine (was 180* btw) and now after i crank the car up and drive it for about 3 minutes, the service engine soon light comes up, and it's code 14, which i think is hot coolant level at sensor, but this happened the first time i cranked the car up this morning, before it could have really gotten hot... everytime i crank the car up, it comes on in about 2-3mins.
is this just a fault error b/c i have no thermostat in? would i be better off with a cooler thermo with holes drilled instead?
(yesterday with my 180*, i ran about 250* all the way to work, would only drop to 230ish at redlights)
86 lg4 sport coupe
Old Jun 12, 2002 | 02:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Usually with CC cars, running lower than a 180* stat will cause computer problems I believe. I would go back with a 180*, and find out what you're problem is.
Old Jun 12, 2002 | 09:32 PM
rezinn's Avatar
Re: coolant question (thermostat)
86 lg4 sport coupe
Change your coolant temp sensor, it's not accurate.
1992 Trans Am
May 10, 2023 07:19 PM
Bstrang6
Sep 8, 2015 04:29 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
