Have a question about a push rode.
Old Jun 13, 2002 | 01:58 AM
89Irocz23's Avatar
Ok I have my intake off right now and was just checking some stuff I noticed one of my push rodes turns very easily unlike the other it takes a lil more effort to turn them. Im like hmm. I always did hear a noise on that side of the engine, but always thought it was a exuast leak. Is that a bad thing or not? Its just that 1 push rode that is easy to turn.
Old Jun 13, 2002 | 02:03 AM
rezinn's Avatar
They should not be easy to turn. You should probably reset the lash on all of them if one is loose. To do this you just crank the engine until the pushrod in question is on the base circle(about 3/4) of the camshaft, and not on the lobe, then spin the nut on top until there is drag on the pushrod. Then go half of a turn more. If you do all of the pushrods at once, then crank the engine over and check again, and again, you're likely to not miss anything. If you find yourself readjusting the same ones, that's just because you adjusted them previously when the valve was open before, no big deal as long as you get it after the engine has changed positions. If you have no idea what I'm talking about, I'm sure you can do a search on "setting lash," and find some better instructions, as mine are a bit brief.
Old Jun 13, 2002 | 02:28 AM
89Irocz23's Avatar
Alright man thanx I'll check it out I know i've done this before with the engine running for a quick fix. The engine not quite able to be ran at this point. I was just scared something was wrong and i was gonna have to replace more crap. This is a rebuilt motor, but I never changed trhe cam, or lifters or any of that.
Old Jun 13, 2002 | 08:49 AM
Vader's Avatar
It's also possible that the lifter on that valve is leaking down slightly.
redmaroz
Apr 25, 2017 07:14 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
5spdcamaro
Aug 28, 2015 02:12 AM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
