Question on aftermarket gauges
Old Jun 14, 2002 | 02:37 AM
NOCANDO's Avatar
Im planning to install a voltmeter and a fuel pressure gauge in my 92 Camaro. I here alot about mechanical and electrical gauges, what will work best for my car......
Old Jun 14, 2002 | 12:46 PM
ede's Avatar
ede
i like mechanical gauges and i'm not sure you'll find an eletric FP gauge
Old Jun 14, 2002 | 12:52 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I doubt you will find a mechanical voltmeter, they are electrical by design. Autometer makes an electrical fuel pressure guage, it's kind of expensive & has a remote mounted sender.
Old Jun 14, 2002 | 07:18 PM
Ricktpi's Avatar
Sorry, had to answer the phone at work & cut it short before I finished. I like a mechanical oil pressure gauge for relability. For the others I prefer electrical, because its easier to route a wire than the 1/8 tubing a mechanical gauge has.
Old Jun 15, 2002 | 11:15 AM
BOTTLEDZ28's Avatar
Transmission: A4
I had this same dilemma when loking for gauges for my car. I wanted to run a fuel pressure gauge and oil pressure gauge.I chose to get mechanical gauges and mount them both in the cowl of my hood. it is strongly not recommneded to run a fuel line inside your car. The electrial fuel pressure gauges are expsenive but its a lot safer. You get tboned on the drivers side with a fuel line there and you will be in a world of hurt it if lights up. Even hot oil is dangerous. If you deisre is run them inside then get electrical ones.
Old Jun 16, 2002 | 07:25 AM
DM91RS's Avatar
Car: 91 RS
Just a word of caution. Autometer has a recall on the short sweep electric fuel pressure guages at this time. The sender starts leaking and causes a fire hazard.
I have all Autometer guages but when I needed a FP guage I purchased a Nordskog. The sender is $40 and you have a choice of a $40 guage and an $80 one. The Autometer was $180. Ouch!
www.nordskogperformance.com
The guage is on the left (not full view)
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
