Guideplate question
Old Jun 14, 2002 | 04:40 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Guideplate question
I have a set of zz3 heads with guideplates and I plan on running a LT4 hot cam. Can I remove the guideplates and just buy the kit that comes with self aligning rockers instead of buying separate pieces and non-self aligning rockers. What are reasons to run guideplates or not run them? Thanks
Old Jun 14, 2002 | 07:28 PM
ede's Avatar
ede
if you have SA rockers you don't need thje guide plates, if you have non SA rockers you need them
Old Jun 14, 2002 | 07:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd just use the GP's and hardened pushrods, probably be about the same cost as SA rockers....but would/should offer better stability at higher RPM's.
Old Jun 14, 2002 | 11:09 PM
allmotorta's Avatar
Most people seem to prefer non SA rockers. If I were you I'd keep the guide plates and go with the non SA set-up. Just my .02
Old Jun 15, 2002 | 01:05 AM
Ok, ill stick with the guideplates.
Old Jun 15, 2002 | 09:10 AM
StangKiller's Avatar
Re: Guideplate question
GM uses self-aligning rockers because it's cheaper than having to mill, drill and tap the heads and install guide plates, but they do work good for most applications.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
LT1Formula
Aug 20, 2015 09:36 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
