testing connections
Old Jun 15, 2002 | 01:39 PM
sunbound's Avatar
Car: 1987 IROC-Z
testing connections
how do i go about testing the connections going to the ignition module? in the past 2 weeks, i have had 3 modules in my car, and i still get a code 42.
what do i do to find the bad connection?
the car runs fine, but the SES light bothers me. im not about to cut the lead to the bulb, just cause i like to know when the computer finds something wrong.
jon
Old Jun 15, 2002 | 07:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, continuity test would be first, but you'll need the schematics. Might be time for a scantool to "see what the ECM is seeing" and go from there.
Old Jun 16, 2002 | 03:07 PM
Vader's Avatar
SB,
I agree - don't disconnect the lamp, repair the problem.
Visually inspect the connections at the EST and the detonation sensor.
Old Jun 16, 2002 | 05:01 PM
sunbound's Avatar
Car: 1987 IROC-Z
Originally posted by Vader
SB,
a freid of mine that used to work on cars and since he got a good job has nothing to do with working on his own stuff told me to disconect the lite.... i just shook my head...
whitch one is the knock sensor?
jon
Old Jun 16, 2002 | 05:02 PM
sunbound's Avatar
Car: 1987 IROC-Z
what scantool would you suggest? and how much?
also, i forgot what software it was and how much., but where can i get the hookup that connects to a laptop and tells you what the computer sees as far as problems with the car.
jon
Old Jun 16, 2002 | 08:35 PM
Vader's Avatar
SB,
The knock (detonation) sensor is mounted in the cylinder case on the right side, just in front of the starter. There is a connector that hangs in the heat from the exhaust and spray from the road that may be deteriorating. Lack of signal there can set a '42' as well.
Old Jun 16, 2002 | 09:20 PM
sunbound's Avatar
Car: 1987 IROC-Z
SB,
thanx vader, im gonna pick up a new knock sensor in a few days and see if that fixes anything.
jon
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
