wireing fuel pump
Old Jun 16, 2002 | 10:05 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
wireing fuel pump
ok guys this is wut i know already.i know that u take the wires from the relay and u hook them up in his way i just need some help here
black/white= ground
dark green/white=into fuse panel on somethign 12v that is only on when the key is on.
orange=goes to somethign 12v that is fused with a 20 amp fuse. my question is do i just run this wire rigth to the positive terminal on my battery? also where woudl i get a little fuse block for this?
ok then there is one wire coming out that i run to the fuel pumpand then i splice it to a oilpressure switch witch i splice into the orange wire.
then there is one more wire comin from the relay that goes to that aldl thing in the G port. how do i know wut one is the G port and how do i hook it into it??
ok and finallyare any of these wires ran where they need to be already or no? and do i have to use an oil pressure switch and hook the one wire to the aldl thing.
please tell me everythingi have wrong. thanks a bunch in advance
Old Jun 17, 2002 | 09:01 AM
Vader's Avatar
Re: wireing fuel pump
89formula#1,
This may help:
Old Jun 17, 2002 | 01:41 PM
Car: 89 Formula
Engine: Carbed 5.7
thanks but thats wut i have been looking at to figure this out and i am still kinda confused. i would like to try to wire the fuel pump up be4 i swap my carbed engine in so that if i mess up i can just hook it all back up again
Old Jun 17, 2002 | 03:25 PM
Brent's Avatar
The answer is very easy if you haven't torn out the TBI wiring yet.
Just leave the FP relay, oil pressure switch and associated wiring connected and the FP will work. When oil pressure builds the pump will run.
There is no need to tear out the current setup.
The first time you start the new engine you will have to fill the carb with fuel manually OR you will have to jumper the FP relay to run the FP till it fills the carb. If you don't, you will end up cranking the engine excessively till oil pressure builds and the FP fills the carb.
All that said, you might consider adding one wire. Connect the starter trigger wire to the terminal C on the FP relay. This will cause the FP to run during cranking.
Ther starter trigger wire can be found at the ignition switch.
Old Jun 17, 2002 | 04:04 PM
Car: 89 Formula
Engine: Carbed 5.7
well the reason i wunted to rewire it was so i didn;t have to use my computer cause i wunna take it all out so it looks neat under the hood. i'm not into the whole stuffin wires here and there. i would rather do it the rigth way ya know
Old Jun 17, 2002 | 04:17 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
You do know that you can't use your high pressure fuel pump with a carb, right?
Old Jun 17, 2002 | 04:23 PM
Brent's Avatar
Re read my post. You don't need to keep the ECM and can get rid of MOST of the EFI harness.
Old Jun 17, 2002 | 05:13 PM
Car: 89 Formula
Engine: Carbed 5.7
tpi guy- i have tbi right now and i am useing a regulator so yes i can use the pump
BRENT- ok so wut your saying is i don't have to touch anything?? i can tear out the computer and all the dumb wires that go to everything but leave everything goin to the fuel pump relay and it will work? also with this wire u are talkin about that goes to the starter trigger, does it make the pump run when i turn the key or is it to make it run longer for the first start up? also u said u run it to the trigger witch is near the ingition switch? were would this be and how can i identify i am runnin it to the rigth thing? could i just run it into the fuse panel on a spot then only has power when the key is in the on position? thanks
Old Jun 17, 2002 | 09:02 PM
Brent's Avatar
No. You may have to pull some wires out of the harness and recover them.
Yes refer to my previous post.
The setup I described makes the pump run while the key is in the crank(start) position.
The ign switch is under the dash on the steering column. I'm not sure what color it is on a 89 Formula. After reading you replies I think it would be easier for you to attach this wire to the starter instead. The starter has two wires connected to it. One is a large cable, the other smaller duty. Connect the small wire to the terminal C on the FP relay. Take a look at the starter and you'll see what I mean.
I don't remember any fuses that are powered during crank only. So I don't think thats possible.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
