white exhaust
Old Jun 18, 2002 | 05:45 PM
camaroluv's Avatar
white exhaust
HI
mabe somone could give me some ideas on whats going on.
some time when I start my car a big poof of white exhast comes out and that it it quits. Is there somthing major wrong or can it be a easy fix. any input would be helpful
thanks
Old Jun 18, 2002 | 05:57 PM
fattie92's Avatar
valve seals?
Old Jun 18, 2002 | 07:33 PM
rezinn's Avatar
White exhaust is coolant, oil would be blue. You may have a leaking intake manifold gasket that lets coolant accumulate on the valves or in the cylinders when the engine is shut off. Check the smoke for a blue tint, sometimes it is difficult to see, depending on the type of oil and amount of it.
Old Jun 18, 2002 | 08:40 PM
camaroluv's Avatar
when I had the hood open finding out my altanator died I noticed a slight hissing sound back that way that I never noticed before could that also be the intake manifold?
thanks for your advice
Old Jun 18, 2002 | 10:11 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
i have the same prob.... i have been told by several of my mechanic buddies that it is just leaky valve seals... and just to watch the oil levels... and that it won't hurt anything unless too much oil is burnt off...
Old Jun 19, 2002 | 01:39 AM
uk89camaro's Avatar
try a search, there's loads of posts relating to "white smoke on start up". It would appear it's most likely the vavle stem seals, followed closely by water in the combustion chamber from blown gaskets or (like mine) a cracked head!
customblackbird
Oct 1, 2015 04:30 PM
cstrobel65
Sep 16, 2015 11:54 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
