1989 Tran Am L98 1.6 Roller Rockers
Old Jun 19, 2002 | 01:05 PM
widow_maker89's Avatar
Hey guys, I have a 1989 Trans Am with the L98 5.7, I want to install a set of 1.6 roller rocker arm, but i dotn really want to change my valve springs? Any suggestions if so what? Remember I have the centerbolt styled valve covers as that makes a difference. thanks in advance Matt Manglos
Old Jun 19, 2002 | 01:18 PM
ede's Avatar
ede
why don't you want to change the springs? at this point they have to be getting weak and wore out. a set from comp or lunati shouldn't cost over 50 dollars fro stock type replacements, but i'd go with aftermarket retainers too and trash the factory rotators.
Old Jun 19, 2002 | 01:46 PM
I only have 65,000 miles on my car, and basically i dotn have the equipment to change the valvesprings on the car. If i were to change the springs, what would you recomend, and how would i go about doing that? As i recall you have a fitting like a sparkplug that fills the cylinder with compressed Air to hold the valves up while you change springs? Are there any roller rockers that will fit?
Old Jun 19, 2002 | 06:34 PM
OK, I only got one response, Again is there anyone who knows if i can use 1.6 ratio roller rockers with stock valve spring?
Old Jun 19, 2002 | 08:20 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Although not suggested you can. I did for several thousand miles before I decided to switch cams. Then I made the switch to better springs. On a stock engine with low miles like yours I don't forsee there being a problem.
I used the Crane Golds with no problems. Most like the Comp Magnums. Both have rockers that are self-aligning which is what you will need. Only bad part is self-aligning is more expensive.
Old Jun 19, 2002 | 08:25 PM
to anyone who is interested i found this https://www.thirdgen.org/oldarchives...ages/11819.htm
and thank you Karps T/A you have been a great help
Old Jun 19, 2002 | 08:31 PM
ede's Avatar
ede
with a stock cam you'll only increase lift by around .030 to around .475. that's pretty much what i conmsider the limit with factory springs. i don't see any real problems keeping stock spring, but i do think it'd be better to switch while you're there
midge54
Dec 27, 2019 04:14 PM
LT1Formula
Aug 20, 2015 09:36 PM
IrocZ'85
Aug 17, 2015 06:24 PM
kyleb24
Aug 15, 2015 08:24 AM
