Low fuel pressure...add an inline pump?
Old Jun 19, 2002 | 04:54 PM
BAK12484's Avatar
For one reason or another my fuel pressure is only at 40 PSI, with the regulator turned all the way up. The previous owner replaced the pump a year or two ago, but I am not sure of the brand. Now I really dont want to drop the tank to replace the pump...if it even is the problem. Everything else seems to be fine - - no crushed lines, new fuel filter, etc... so I was wondering if I could just install an inline fuel pump?? What kind should I get and where should I mount it??
Old Jun 19, 2002 | 11:08 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
First of all, how much voltage is the fuel pump getting? How old are your injectors? they could be leaking. When you say you have the regulator "turned all the way up", i'm assuming you have an adjustable regulator. It could be the pump, but it could also be a weak diaphram spring or the diaphram valve itself not seating and/or leaking. And no, installing an inline pump isn't the best way to go because you will need to remove your old pump anyway (and don't tell me you're going to run two pumps at the same time!), at which point you could just put in a good high volume performance pump in there and be done with it. Inline pumps usually have to work a lot harder to move gas and subsequently get nice and hot and could fail on you (keeping your old pump in there will make this a lot worse).
Old Jun 19, 2002 | 11:55 PM
BAK12484's Avatar
i'll have to check the voltage at the pump and see what it's at next time i get a chance to.
As for the injectors, I haven't the slightest clue, but am guessing they are fairly new as the previous owner did a lot of work to this car.
Anyway i could pull the adjustable regulator off and test to see if its working properly??
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
NBrehm
Aug 25, 2015 11:49 PM
92camaroJoe
Aug 13, 2015 06:07 AM
