wierd noise from rear of car, i'm stumped
Old Jun 20, 2002 | 04:17 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Today while driving I started hearing this intermittent noise from the rear of the car. Every once in a while it will sound like a drier full of nuts and bolts spinning and then this distinct 'clunk' like dropping a bolt in a metal pan. Then all will be quiet for 15-20 seconds and the process will repeat. It sounds like it's coming from the muffler but it's hard to tell. It happens regardless of vehicle speed, engine speed, gear i'm in or if the clutch is up or not so I don't think it's a driveline thing because it'll do it when the car is stopped. No abnormal sounds from the engine either. It's not the fuel pump because it's disconnected since I'm using a mechanical one. Only thing I can think of is something got into the muffler and is getting knocked around.
Any ideas? It's really annoying.
Old Jun 20, 2002 | 09:49 PM
rezinn's Avatar
Do you have a catalytic converter?
Old Jun 20, 2002 | 09:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd check the cat too.
Old Jun 21, 2002 | 12:17 AM
Car: '87 Camaro LT
Engine: 355 L98
I don't have a cat. A friend of mine said the muffler's broken apart. The exhaust hasn't gotten any louder though, it's odd. Guess I'm goin muffler shopping which is kinda good cuz this one's been annoying the neighbors. I like how the (gasp!) 5.0 Mustangs sound, who makes one that sounds like it?
Old Jun 21, 2002 | 12:24 AM
breathment's Avatar
the mustangs sound that way cause of the engine and the true dual exhaust. i kinda like that sound too, but ur never gonna duplicate it.
Old Jun 25, 2002 | 05:13 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Did you check your rear swaybar links? I had one that was broken, and it appears from your description of the sound, to possibly be the same thing I experienced...
Old Jun 25, 2002 | 11:37 PM
Car: '87 Camaro LT
Engine: 355 L98
it's not the swaybar links because the noise happens even if the car is standing still.
oddly enough, the noise seems to have gone away and the exhaust is now quieter a little, go figure. whatever was rattling probably got wedged somewhere
BRoss99
Aug 10, 2025 05:08 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Elliswon
Aug 10, 2015 12:33 PM
