Non-mechanic needs help
Old Jun 22, 2002 | 09:09 AM
junglecat's Avatar
I have a 1985 Z28 with a 305. I have a mechanical fuel pump and it looks like oil is leaking from the top of it, is this possible?
TIA junglecat
Old Jun 23, 2002 | 01:15 AM
jeffs82z28's Avatar
Welcome to the boards
Yes, I suppose it is possible.
Get yourself a can of brake clean and a couple of rags, a drain pan to catch the hazardous wastes and some saftey glasses/ goggles.
Put the pan under the pump and spray it down with the brake clean and wipe it with the rags till it is clean and dry.
Start the motor and let it idle and watch for the leak.
Good luck
Old Jun 23, 2002 | 03:06 PM
ede's Avatar
ede
yep it happens, replace the fuel pump and all should be well
Old Jun 23, 2002 | 04:31 PM
junglecat's Avatar
Thanks guys for replying. Im going to change the fuel pump and i hope this helps my problem.
junglecat
sogabe
Jun 26, 2008 07:16 PM
Bill Speed
Nov 30, 2004 12:46 PM
540sixgears
May 24, 2004 08:42 PM
cgacfox
May 29, 2003 04:31 PM
esams
May 15, 2003 12:33 AM
