Esc
Old Jun 24, 2002 | 10:43 AM
tpi_roc's Avatar
Esc
Would anybody agree with my suspicions that on a 350, with a 350 knock sensor, and a 305 ESC would only make my ecm more sensitive to knock? And would only positivly help in minimizing actual knock with minimal negative effects? (short of to much retard lessening performance)
Old Jun 24, 2002 | 11:09 AM
ede's Avatar
ede
no, why do you think it would, but i'm not working for NASA either
Old Jun 24, 2002 | 11:47 AM
tpi_roc's Avatar
Im assuming the 305 knock "setup" is going to be more sensitive due to the thicker cylinder walls and less power (stock), I figured 305 sensor/ESC would be extra sensitive in a larger engine with thinner cylinder walls.
Why do you feel otherwise?
Old Jun 24, 2002 | 12:41 PM
iroc22's Avatar
Im pretty sure the 305 and 350 share the same knock sensor. I'm not so sure about the 305 and 350 sharing the ESC however. It's a good theory you have, though I don't know if there really is any substantial difference to make it noticeable.
Old Jun 24, 2002 | 12:50 PM
tpi_roc's Avatar
Im becoming more currious...
does the esc in fact act as a "filter" to what the knock sensor sends it as knock? Or does it simply start throwing out retard?
I'd be currious whether they're so "tuned' together that a knock count on a 350 sensor wouldn't register within filtered limits of a 305 esc module, assuming I'm even understanding its functions correctly.
L98GTA87
Oct 19, 2015 10:43 PM
GTAman
Sep 21, 2015 09:57 AM
RGB2015
Sep 20, 2015 09:26 PM
db057
Sep 4, 2015 07:57 AM
RyanJB
Sep 2, 2015 01:27 PM
